Hitachi M12V or PC 7518?
  • jussi
    • 2162
    Someone is selling a PC 7518 for $225. I currently have a Hitachi M12V. Is it worth selling the Hitachi and getting the PC. Alot of people have said the 7518 is the industry standard for 3-1/4 HP routers and that it's a much better router but I haven't figured out why. What features will benefit me in upgrading? What does the PC have that the Hitachi doesn't. Also I haven't used the Hitachi yet and I'm still waiting for my bench dog table and still haven't made up my mind on what plate to get. Thanks.
    Can't speak to the PC, but I am a very satisfied M12V user. I have mine mounted in a Woodpeckers Quick-Lift, and have run into nothing at all problematic, much less anything that would make me want to make a change.
    • ragswl4
      • 1559
      • Winchester, Ca
      • C-Man 22114
      If you recently ordered the benchdog pro it comes with a plate.
      RAGS
      Raggy and Me in San Felipe
      sigpic
      • Thom2
        • 1786
        • Stevens, PA, USA.
        • Craftsman 22124
        If it's mounted in the woodpecker quick-lift, the it's probably the KM12VC. The M12V is stricly a plunge router ... much different setup
        As for the 7518 vs. the M12V .... I had the M12V, but never the 7518 .... IMO, the 7518 is much more adaptable to a lift in the future, the M12V is an EXCELLENT router for what it is, but it's got many drawbacks in the grand scheme of things.
        That's a really decent price on a 7518, I'd probably jump on that
          No Thom, it's an M12V, but I misspoke the lift... It's a Woodpeckers Plunge Lift. It's been a long day...
          By the way, the PlungeLift works great, runs up and down without a hitch and holds that big honkin' router rock steady. I've done a lot of blind cuts that would choke a lesser machine, and never a problem.
            I can't compare the two routers against each other, but can tell you that I really like my 7518, which I have mounted in a Rockler/JessEm Mast-R-Lift. I've owned it about three years, I guess. Never a complaint, never a hiccup.
            I paid somewhere around that same $225 for it, new; but that was back in the halcyon days when amazon.com offer heftier across-the-board discounts than they have been lately. I've not seen a new one for anywhere near that price in a very long time.
            • Jeffrey Schronce
              • 3822
              • York, PA, USA.
              • 22124
              Absolutely 7518 over M12 IMHO. The 7518 in a lift is head and shoulders above the M12V in a lift. The 7518 will come out of the base thus allowing the motor to be mounted in a lift which will extend the entire motor up through the base plate. This is awesome for bit changes. Looking at Woodpecker Plungelift they still recommend a collet extension for above table changes which is a major weakness IMHO.
                Although I have the offset collet wrench, I do use an extended collet, and it is not at all awkward or troublesome. To each his own ('course I did get the router for $80 when Amazon had that screw-up last year...).
                • Knottscott
                  • 3815
                  • Rochester, NY.
                  • 2008 Shop Fox W1677
                  Not all collet extenders are created equal. Those that add vibration aren't so desirable...
                  • Jeffrey Schronce
                    • 3822
                    • York, PA, USA.
                    • 22124
                    More importantly the collet extender could have deflection and will also magnify any runout or mis-alignment.
                    Having said that I have used collet extensions without any problems. As you note however not all collet extenders are created equal. Woodpeckers extension is listed at $80. Add that to cost of router and the M12V quickly gets into 7519 territory.
                    BTW, is that a private deal on teh 7518 for $200 or is it a store? Thats a good price.
                    • ragswl4
                      • 1559
                      • Winchester, Ca
                      • C-Man 22114
                      I have the M12V and change bits from the table top without a collet extension. I use a bent wrench. Works fine.
                      RAGS
                      sigpic
                      • jussi
                        • 2162
                        Craigslist deal.
