I was using a hole cutter and bogged down my drill press today. When it fired back up, it was running backwards. I tried to stall it again and see what would happen but it is still spinning the wrong direction. It is an old Craftsman(40 or 50 years old) that is in fine shape but it does not seem to have the original motor. Whats up?
My drillpress is running backwards
Woa... Weird... Does it have a starting capacitor on the motor? If you spin it first and then turn it on does it continue in the right direction or stop and spin the other way?
Bill"Why are there Braille codes on drive-up ATM machines?"Comment
More than likely the start-up capacitor or something associated with it, is on the fritz. I might even be possible to force it to start in the right direction by spinning it, or moving the belt in the right direction and then turning it on. Watch your fingers though.
This advice is given without assuming any of the possible consequences of following it.
TimSometimes my mind wanders. It's always come back though......sofar!Comment
I believe that the polarity on the framistan has been reversed. I've heard that this is quite common on older model namstfarC drill presses._________________________
"Have a Great Day, unless you've made other plans"Comment
If it's running backwards, it should be pretty easy to catch, unless you are REALLY out of shape.
Oh come on...I'm the 5th person to respond and I'm the first to come up with the classic pre-pubescent "Is your refridgerator running" crank call? Hey, wait a minute, maybe that is saying something about myslef...JoeComment
Afer a short chase, I have recoverd my wayward drillpress but I still have the problem. I tried spinning it the opposite way on start-up with no luck. i still have one question . What do I try next?spellling champion Lexington region 1982Comment
Counterclockwise (left-hand) bits.
(sorry couldn't resist)
Assuming we have an single-phase induction motor (most all drill presses we find in home workshops do) then we know that the direction of rotation of a such a motor is goverened by a start capacitor (which is across one pole of the motor to cause neough delay in the field to make the motor start in one direction). I can't offhand imagine how the wiring could be reversed to the other pole. One reason might be that the start capacitor simply opened up or became un connected in which case the motor generall sits and hums when started unless pushed in one direction or the other then its runs in that direction. But you already tried spinning it the right way before starting and it reversed which says the starting cap is affecting it.
Maybe you did wake up in an alternate universe.Loring in Katy, TX USA
Oh yeah. You didn't let the smoke out did you? Even Loring will tell you that when they build those start-capacitors the put smoke in 'em. If you let the smoke out they don't work anymore.
Is it reaching full speed in reverse direction? I kind of suspect the starter switch in conjunction with the capacitor. At least take the end off and check the starter to see if everything seems in order.Sometimes the old man passed out and left the am radio on so I got to hear the oldie songs and current event kind of thingsComment
Oh come on...I'm the 5th person to respond and I'm the first to come up with the classic pre-pubescent "Is your refridgerator running" crank call? Hey, wait a minute, maybe that is saying something about myslef...Comment
I wonder what the Matag repairman is up to. Perhaps I should give him a ring.spellling champion Lexington region 1982Comment
I'm guessing that the starting capacitor has gone south. I suggest you inspect it, they usually leak a little oil when they go and will even show signs of overheating. Make sure you disconnect power before checking.
Another way to check it is to disconnect one lead from the capacitor, plug the drill back in and turn it on. Does it react as before?
Capacitors can also be checked with an ohm meter. The capacitor must first be disconnected from the circuit. Put the ohm meter on the highest resistance scale. Put a meter lead on each lead of the capacitor. The meter should show a low resistance, then increase over a short period of time. Reverse the ohm meter leads and the indication should repeat. It can be difficult to see with a digital meter. Analog meter is better.RAGS
Raggy and Me in San Felipe
sigpic
Footer Ad
