Glue for melamine?
  • jussi
    • 2162
    Glue for melamine?
    What type of glue do you use for melamine and mdf?
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    roo glue is specifically for melamine surfaces. otherwise regular wood glue.
      Yellow glue works good for MDF and particle board. Melamine joints will benefit by doing shallow dadoes and rabbets, like 1/8", just to get a glue joint, and in those you can use PVA or aliphatic resin glues.
      • Mr__Bill
        • 2096
        • Tacoma, WA
        Titebond makes a white glue for that called, Titebond Melamine Glue. It dries sort of translucent-white. Sticks to the Melamine better that just yellow glue but not as well as an epoxy. However the Melamine surface itself can peel off of the particleboard so no glue on the Melamine surface is structurally sound. As mentioned a dado joint even only a 1/16" is much stronger and then you can just use your yellow glue if you like.
        I found Titebond Melamine Glue at a Woodcraft store, one advantage even in the dado joint is the sort of white glue line blends with the surface.
        Bill,
          • 9563
          On the few occasions I have glued up Melamine I did the dado skim trick, and used Gorilla Glue. That stuff works great, but is a pain to handle sometimes...
          For pretty much everything wood, MDF, particleboard etc... I have been using Titebond II with good results. I have Gorilla Glue and use it for exterior projects, or stuff that I know is going to get a LOT of abuse. LOML's step stool is glued up with gorilla glue.
            +1 for good ol' yellow glue. Hasn't failed me yet for melamine or MDF.
              Skinning the melamine with the shallow dado works good, and makes placement and clamping much easier than a gooey, loose joint sliding around while wet.
                I have the book on melamine joinery by A. Kinsey, that explains this condition...pages 202-288.
                • jziegler
                  • 1149
                  • Salem, NJ, USA.
                  Is that the same Kinsey that there's a movie about?
                  • Mr__Bill
                    • 2096
                    • Tacoma, WA
                    a dirty mind is a joy forever
                      Bill,
                      For those shallow rabbets/dadoes, I found from experience that a depth like 1/16" will work by getting exposed substrate, but it presents itself as easily damaged when dry fitting parts or during assembly. I tried that depth and found that a 1/8" depth works well in providing more shoulder for the rabbet/dado, and being deep enough to offer some protection of the melamine edge from getting chipped off. And, if the male part has any chipping, it may get hidden. Just my .02 cents.
                        are you trying to glue the MDF to the smooth face of the melamine or talking about glueing to the exposed particleboard substrate on the edges or inside dadoes/rabbets?
                        • Mr__Bill
                          • 2096
                          • Tacoma, WA
                          good point.
                          I was thinking in terms of a butt joint where the dado is really only removing the melamine and not really making a joint. With light sanding of the dado and the edge of the mating piece a 1/16 dado saves you trying to make a dado that is 1/32 over 3/4. It is after all melamine and not fine cabinet work.
                          I know I shouldn't use junky technique when making junk but I save my energy and sanity for things that I take pride in.
                          Bill, over here on the other ocean
                          • jussi
                            • 2162
                            Sorry for any confusion guys. I'll be making a router table using a couple sheets of mdf and top it with a melamine. So I'm asking what type of glue to use to join a melamine sheet to mdf.
                            • Mr__Bill
                              • 2096
                              • Tacoma, WA
                              Ah a lamination. I would suggest contact cement. But.... if you think you my at some time want to replace the Melamine top you could just screw it together from the bottom. The other way is to use 3 layers of MDF and cover it with a plastic laminate like Formica. The Formica would wear much better than the Melamine and if you are going to have to buy the Melamine the laminate in a small piece may be about the same price.
