I did a couple of window decorations on the scroll saw for halloween. They are not my design, but from the book "Artistic Scroll Saw Patterns and Projects"....here they are....
![](http://www.swordandspiritsoftware.com/Images/WoodWorking/HalloweenScrolling.jpg)
I also turned a pair of wands, as my wife and I went to a Halloween party as Lupin and Tonks from the Harry Potter series.
![](http://www.swordandspiritsoftware.com/Images/WoodWorking/HalloweenWands.jpg)
They are both poplar, stained the top one walnut. The ball end of that one was interesting to create, and I did make a little tip sanding "jig". I basically cut a 1/2 circle by plunging a core box bit into some oak. I then filled the hole with sand and did the boy scout fire trick to sand the tips smooth.
