Brain not working. Here is my small project: ~5/8" thick baltic bearch ply, 8" x 22" size. I need to put a 45 degree bevel on each edge -- 1 side only. I need to remove only a small amount of material -- about 1/2 the board's thickness.
The two short ends went ok, I used the sliding table for a crosscut. Then the long edges came along and...? How do I do it properly?
I have standard BT3100. I have my sliding table to the left of the blade, my rip fence is usually on the right. It seems I cannot do the rip cut without trapping the workpiece between the blade and the ripfence. I did this on an almost identical piece a few weeks ago -- the cut was not smooth and the workpiece was burned.
This time I vowed to do it right. I put the sliding table to the right of the blade, and then ... tried ... to put the aux table to the left of the blade. It won't fit! Parts of the main saw are preventing the aux table from going there!
What to do? Move my carefully positioned guide rails that now cut perfectly to the inch scale or burn another board by the trapping method? Use the Bandsaw instead? What am I missing? Please assist.
